remote id inside lampshade
OH MY! .. I cant even read what the brochure says... Guess I won't buy one.
Not buying from OVERSEAs any longer. Will start looking into U.S. companies for drones purchases in the future.
Hello
I bought my H3 this month :) !
But in france and now in EU we have need remote id.
My id for make uav under 2kg is to place a light part like this https://www.signal-drone.com/wp-content/uploads/2020/12/Manuel_SD20L.pdf .
Did you know if we have realsense connector in lampshade and the volatage in this connector ?
Thanks
It would be best to have the remote ID as a separate system with its own battery, it will only take a very small battery to run the ID device. This way there is no possibility of the remote ID electronics causing an issue with the H3. If you wire them together there could be an interaction as the H3 was not designed for integrated remote ID.
Reactions: WayPoint
Yes i understand for battery but if i put batteri for remote id i pass 2000kg and i need to buy emergency landing système for flying next to people (10m)
jonnyelectric
