Replacement for the Typhoon H GUI
In the old version of the GUI, you can see unlocking and locking, but in this new version of yours, you can't see it, there is no possibility to enter the managed code
I'm a little boring.
Do I have to go to the GUI and press NFZ again every time the drone starts up, or is it enough
once and that's it?
I don't know. I have no NFZ in my area to test this. But I think it is the same like the geo-fences. Once changed the FC keeps it for the next time.
Once the license file is installed to the F/C it should be retained. The Yuneec GUI should then allow you to also alternate between NFZ active/inactive in the same manner as setting the Geo-fences.
The new corrected and updated H480_GUI is now available at my download area:
Source code is available in GitHub:
The license file handling is now as follows:
  • No license file in home folder: NFZ buttons not visible.
  • There is a license file (uploaded with "Open license file") in users home folder: NFZ buttons visible, but disabled.
  • The license file belongs to the serial number of the flight controller: NFZ buttons visible and enabled.
  • The license key is invalid: Sending a command to flight controller (enable/disable NFZ) will be responded by "Invalid"
  • You have a valid license file that belongs to the serial number of the flight controller: Sending a command to flight controller (enable/disable NFZ) will be responded by "OK". In this case you are able to disable NFZ if needed.
Note: Enabling the NFZ buttons is not proof that the license file is valid, neither in the original Yuneec GUI nor in the alternative H480 GUI.
Thanks for the message.
I reinstalled everything,
renewed the license in the NFZ tool and it doesn't work,
the GUI says invalid
Does the ST16 also have to be connected to the drone when doing this?
No.
My conclusion is that I obviously do not have a valid license and how do I finally get a valid license by serial number?
Yes, that is what the flight controller responses.
Currently I do not know who is doing that. Since Yuneec Kaltenkirchen is out of service the support is very bad.
kopterbude.ch has not got the official Yuneec tool but he is trying to get it. I hope he will ...
There is a repair service in Poland. Maybe they can help.
khurtt
