Replacing the H St-16 battery
To replace the St-16 rechargeable battery, YP-3A, it appears that I have to remove the back of the St-16. If that is correct does anyone have a video link that would show me how it is done?
Thanks!
Just slide the cover plate down and disconnect the small EC connector. You don’t need a video, you really don’t.
Pat. Do you need to take the back off the ST16 or do you just pull on the connector to get it out?
Slide off the back plate, pull on the blue ribbon and disconnect the blue plugs. Easy
It is one of the great design decisions made by Yuneec. Replacing this battery is nearly as easy as replacing the battery in the drone itself. I have multiple H's (and therefore multiple controllers) and forgot to charge the controller for the one I wanted to fly. Just swapped the batteries from one controller to the other and was in business.
Note: I have different cams on the different H's which is why I fly one over the other.
LorieMcCor
