Rubber damper loose on Typhoon H
Moxie,
I had the same issue and it wasnt such a big deal but frustrating to take it all apart because one damper keeps popping loose. If it is the same corner over and over try just flipping the damper upside down the other direction i found that. My problem damper had o e side that was much softer than the other. I put that side downward and put the shock/weight on the other side. I have not had a problem since!
Sent from my LM-Q710.FG using YuneecPilots Drone Forum mobile app
RohmadFauzi
