That is a very naive statement. China is a source for a huge number of counterfeit and inferior products of all types.If it says yuneec on the blades they are genuine yuneec props. The packaging is original as well so It seems your safe.
That might be so but illegal branding is an offense even the chinese won’t burn their hands on. They sometimes change the logo or swap letters in the brand name but these are definately genuine yuneec blades.That is a very naive statement. China is a source for a huge number of counterfeit and inferior products of all types.
That’s really odd. I have 6 of them and all but one came perfectly balanced. It needed a little bit of sanding but it took me less then 5 minutes to get it perfect. Maybe you got a “friday 4:45 batch”I just ordered two sets of Maytech MTCP9060H carbon props at the same company that Crazy Crow provided a link to earlier in the post. Frankly, I am disappointed by the balance of these props. Of the 12 props, only 4 could be considered to be balanced. Strangely these were all props which had no trace of sanding on the underside of the blade. Generally, I check the balance on any prop I use but the balance issues on them were far beyond what I would expect from a "Hand Balanced Propeller" as Maytech claims to deliver. In fact, one of the props was actually gauged (see photo). I wrote to MCHobby but no reaction. Maytech themselves have a non-working link to their "Online Feedback" so that is a dead end as well. At the end of the day I am sure I will be able to salvage these props and get them balanced but in all, my expectations have been lowered by the failure of this product to live up to promises made.View attachment 9187
Balance by adding weight, not subtracting. Use strips of thin, clear packing tape on the convex side of the blade.
Why would it be bad to sand your props? Even the factory sands their props for balance. Also it’s beter to lose weight than add weight imo.If you guys are sanding on thin, plastic blade props you’re courting disaster. I would expect any that had been sanded ti fail at some point. Balance by adding weight, not subtracting. Use strips of thin, clear packing tape on the convex side of the blade.
Pat, please clarify for me... I also add weight... just a touch of CA glue... but everything I have seen on prop balancing says to apply the added weight to the underside of the prop... the concave side. You do not want to disrupt the airflow on the convex top side of the prop, as to not interfere with lift, correct?
@Crazy CrowWhy would it be bad to sand your props? Even the factory sands their props for balance. Also it’s beter to lose weight than add weight imo.
And if it makes any difference, they are carbon props.
I’ve had the opposite experience with using tape. It came loose during flight causing drag on the prop. This in turn caused irregular behaviour which affected the aircrafts stability.
I used to add tape all the time but switched to sanding after that incident. Never had a problem since. No prop failures or anything
I see now where this conversation has taken a wrong turn. I was talking about the carbon Maytech props.Crazy Crow:
Can you establish with no doubt H props are carbon? There is no discernible weave and if you break one there is no evidence of carbon fiber. At best H props might consist of a carbon paste which is weak without the cloth as supporting structure. If you’ve done any work with composite laminates you would know it’s strength is in large part obtained from overlapping and bias of the fibers. H props have no fibers.
As true CF props have very few layers of laminate it’s quite easy to sand through a layer and weaken the prop. Sanding works well on thicker wood and stranded fiber props but not so well with structure as thin as ours.
Sure, Chinese prop manufacturers sand props to balance them. They only have to be in one piece when you get them. If they break you’ll buy another from them. Guaranteed repeat business. OTOH, you’ll never receive a sanded prop from quality manufacturers of larger props.
Thanks for the advice Pat. I will definately take it with me for future purposes.Not trying to get on your case, but to educate. Maytech, like Sunnysky, Turnigy, and most Chinese manufacturers, is in business to make as much money as they can while expending the least amount of capital possible. The only thing they care about is making money. They are not in the business of customer care.
Most of them fail to provide accurate or well thought out user instructions although they have the ability to do so. In that failure the stage is set for those lacking experience to make mistakes that end up costing the users more money to replace what they broke or caused to break trying to figure things out.
Where props are concerned I hope you’ll at least listen to advice provided by people with many years of RC and full scale aviation experience. They share knowledge of common maintenance principles applicable to both types of aircraft. Of course you can do what you want of feel is best for you, nobody is trying to prevent that. All we are trying to do is give you information that will help you do things better over the long run and eventually save you money.
BTW, if you clean props with alcohol to remove mold release agents before applying tape it tends to stick better and longer.
