ST10 UPTUDE
Hello,
I accidentally installed the st10 + software while updating st10 software today. The device was black screen. How can I fix this?
Yep... CS is about your only hope.
Have you tried pulling the Sd card from the box and trying to boot without the card ? I doubt it will help but worth a shot.
Do you see the "Android logo" at start up before the black screen ?
If you do, there's good hope CS can fix the issue.
No logo and your chances for recovery drop off pretty sharp.
Hoping you can find a solution....
Good luck,
Jafo
Good luck,
Jafo
Actually, since this is caused from the wrong firmware being installed, they can restore the ST10. This has happened many times in the past so it's not permanent damage.
tottagirl096
