ST16 Configs retained after disconnecting the battery?
Hello all,
When I disconnect the battery from the ST16 Controller, is it supposed to retain the config settings such as return to home altitude, etc...?
I've seen posts about the C23 retaining photo settings in between battery changes on the Plus, but I do not remember seeing anything on the ST-16S during a battery swap. Write down the settings you are concerned with, and let us know!
Just for clarity you have the ST-16S, correct? The ST-16 is the controller for the H Std or Pro.
Hello all,
The config data like altitude, rth etc. are actually written in the drone. So when you restart or swap the battery in the controller the data comes back the second you reconnect the st16s to the drone.
But it is always a good idea to check the settings before you take off.
CKHD
