ST16 Controller Passworded
austin ark
bought a used typhoon h and cant get past the password screen the default ones dont work. so ready to fly again but all i got is a paper weight please help thank you
cant get past the green screen no factory pass words work then it blacks out dont know what direction to go to fix it
awsome if someone could help my dee dee dee self fix this
thanks
Reactions: pat4si
If you mean the ST16 screen lock (Green Screen with password features), this is how it is done. (This process is ONLY for the ST16 and ST16 Pro. Other methods are used for ST16S series.)
ST16 Unlock for Typhoon H
If you have a plain Green Screen with no password related features, please let us know.
If you mean some other password, please let us know which one.
i clicked on the web sight you posted but i dont know how to run the file after i hook up the controler hate to seem so dumb but im not tech savy
thanks
Hit the enter key on your keyboard.
You should get a new line, same as the first, and it will have a flashing white box at the end of the line.
Type in the command as shown in the instructions, then hit the enter key to send the command.
thank you so much im away from that **** green screen and ill be flying tommorow afterwork
Good job.
Remember to set the date/time/WiFi. Many folks use Standard time year-round since the GPS satellites stay on Standard time year-round.
You will also need to create a new Model on the controller and bind the controller to the drone and to the camera.
Let us know if you need help with any of these items.
Reactions: DoomMeister
Sorry to resurrect such an old post but I'm also stuck. Downloaded and installed the fastboot file however after I initiate the command the response I receive is:
error: no devices/emulators found
I can see the portable device under file explorer. Any help would be appreciated.
You would normally only get that error if the USB cable was not data capable or if the Typhoon H was not powered on. You mentioned you could "see the portable device under file explorer". Was that noted when reading Step 6 of the instructions?
Must be past my bedtime. Correct that to "ST16 was not powered on".😒
So the Typhoon H is not on. I only have the st16 connected to the computer via usb, running fastboot per instructions. All is good until I get to step 8. Instead of the st16 rebooting, I get the error: no devices/emulators found
on the command line.
Is the controller battery at least above 50%?
When you installed ADB, did the system install a bunch of drivers?
I didn't notice any drivers installing. I am suspect that it is a driver issue but device manager reports the device anzhen4_mrd7_w is operating so it sees it.
I didn't notice any drivers installing.....
It has been forever since I installed it. I might even be confusing it with some other utility.
I am messing with a spare controller trying to get it to mess up, but so far no luck other than one USB data cord had failed. But that one did not even let the ST16 show up on the PC screen.
Try removing the controller battery, wait a few seconds, then install the battery and try again. And use a different USB cord if you happen to have one handy.
I am messing with a spare controller trying to get it to mess up, but so far no luck other that one USB data cord had failed. But that one did not even let the ST16 show up on the PC screen.
Gotcha. Yea, I tried all of those suggestions before I posted. It's not the cable or battery unfortunately. There's got to be some way to get past the security pattern..
Jimmyray
