ST16 new firmware update question
Australia
Hi Guys
so did the update, and this is what the update looks like on the screen, can i ask if it is the same as the guys that have updated?
just the st16 update.
Hi!
Let the camera connected to H and look version page again.
Mine was showing also N/A. After camera connection version info was ok.
Best regards
Hi!
Best regards
mine says N/A cause I don't have the H on, just asking if everyones ST16 update bit looks the same, just the 2 lines of info.
Make sure you recalibrate accelerometer then turn drone off then back on the Calibrate camera turn off then calibrate compass. Order doesn't matter just make sure you reset after each step.
I have a question, I just finished updating the H and at take off it hesitates. Is this normal or is there a fix for this?
ghost333
