- Joined
- May 22, 2026
- Messages
- 2
- Reaction score
- 2
Hi all,
I recently ended up with a Yuneec H520 drone with ST16S controller. It was free. Had been crashed, with some broken bits. It's barely used, the owner got aggravated after crashing it, stuck it back in the box and left it to sit for years.
The broken stuff looks easy enough to fix. The drone batteries take a charge, and the drone itself powers up (I've since read that you're not supposed to turn on the drone power without the controller being ON first - oh well).
Question is about the ST16S controller. The battery is dead (2.46 volts). I found replacements available for ~$70 or so.
So here's my question - should the ST16S power up with no battery (or a dead battery) - just the USB micro connector hooked up to a charger (typical cell phone charger cube)? This one does not power ON when hooked up to a charger and switched to "ON". If it is supposed to, then I guess the controller is dead, and I probably shouldn't spend any $$ on it.
Thanks!
Thanks!
