ST24 and Q500 4K
Can you use the ST24 with the Typhoon Q500 4K ????
I don't know that anyone has tried. If you create a new model and if you can get it to bind, it will probably fly within the limits of the Q. I have no clue if the control functions are on the same telemetry channels but I have used the ST16 to bind to the Q. If you can successfully bind you could give it a try in an open field without the camera attached.
Axel66
