technical problem
ayuda .... tengo problemas con la grabación de la cámara cgo03 .. en el momento de ver el video aparace con una interferencia en la parte inferior que hago
It would be helpful if you could use Google Translate when posting. This forum is international but the posting must be in English.
I have seen this type of problem in the past. It was caused by
1. Defective card reader.
2. Poor sd card.
Reactions: rdonson
2. Poor sd card.
Thank you Steve Carr, it would be appropriate to change the SD then. because when I download the video to my pc I do it through HDMI.
So you are getting the photos and video from the ST16?
Have you checked the sd card in the camera?
if I actually have time in video 16 you see the recording well you do not notice anything, the video is played on the street you can show the error, but where the information is displayed directly on how to download and play on the TV or computer personal. You can now download the video directly from the computer to the computer or the computer to the computer. it seems that when you turn the camera you see the image and take a spinning measure.
The video and pictures recorded on the ST16 will be terrible quality.
You must remove the sd card and copy the pictures and video to your computer.
dubaiseocompany
