Terminal shroud pulling back
It appears to be poor construction. Is the pin tight or does it move around? If the pin seems tight I would simply add a bit of epoxy to fill the gap.
Hi Steve yea the pin is tight I have contacted Gifi with pictures as it was only bought this year
Good idea. I doubt that it will cause any problems if you are using the stock charger. If you are using an EC3 connector to charge then it may be difficult to seat.
Am using a ec3 adaptor it was a bit tough to go on hence why I think it did not charge fully although my charger showed all cells full but when came to using the battery once up in the air it went to 10.8 will wait and see what Gifi says
Car20ret
