Where do you point if your bang centre in the middle of the north pole?
and the evidence is ...I think it is bad luck to be superstitious. ?
not so much as a superstition, as it is a habitI don't have evidence. But a typical IMU unit contains Gyroscopes, Accelerometers, and Magnetometers. Direction probably doesn't matter much to accelerometer, but it sure sounds like it would matter to Gyroscope and magnetometer. Bear In mind "Accelerometer Calibration" is just a phrase translated from Chinese for whatever the process is actually doing. For all I know, the correct translation might have been "IMU calibration".
I think I will fail on the conservative side and pay attention to the direction from now on.
(Hope I don't need my mirror again.)
Every direction but one. DOWN is north. At least that's what your compass would tell you if you stand it on edge.Doesn’t matter. Every direction is South.
Ummm, bad luck is a superstition ?
Not if the habit becomes an obsession.not so much as a superstition, as it is a habit
Translated; from French to EnglishBonjour, Je n'ai pas lu tous les messages qui précède, mais de la mémoire, l'étalonnage de la boussole et du gyroscope est une remise à zéro important de faire les 3 autour des sorties, il maintient le drone stable en vol et un RTH parfait sans mauvaise surprise backd, orienter le nord face drone est inutile ..
Après les 2 nords, parce qu'il ya 2:
_la nord boussole / boussole, il est magnétique.
_ La carte nord / nord géographique, il indique aussi le nord , mais avec un réel changement à prendre en compte.
différence entre les 2 nords de plus de 50klm.
Ceci est appelé déclinaison magnétique.
A couple of days ago, I booted up and took off from a sloping surface. The TH immediately straightened itself up to level and flew normally.As we don’t want the secret to get out we won’t mention the H calibrates the accelerometers during every boot up process.
