Typhoon H arm latch replacement (metal part in main body)
I need to replace 2 of the aluminum catches that snap into the arm metal retainer.
Is there a video on how much of drone I need to remove to get to the retaining screws?
Tim
You do need to remove the top shell. Remove the six 1.5mm hex screws from around the edge of the shell. Unsnap the latches on each side of each motor opening. Disconnect the GPS connector.
azmachinegunguy
