Has anybody tried using typhoon H plus blades on a 520 they’re $20 cheaper? Is there any difference ?
Ummm... bad Judge we have?Nah.... you just lost the daily double...
I'm told by Yuneec UK that they are different. Certainly I know you can't use the same charger, I've tried. The H batteries have a lower power output but will work in the H520 and so the flight durations are less.It is like the H+ and 520 batteries, exact same cells, in different color cases and the 520 is $20 more. ?
I'm told by Yuneec UK that they are different. Certainly I know you can't use the same charger, I've tried. The H520 batteries have a lower power output but will work in the H520 and so the flight durations are less.
Apologies Phaedrus, simple typing error!Oscar, you might want to edit your post. You state H520 for both sides of your equation.
The H520 and H Plus batteries are the same, and both can use the same chargers. Example: DY5 will handle the H520 and H Plus LiPo HV (high voltage) packs.
It is the H480 (Typhoon H, H Pro) that used the LiPo batteries. These require a different charger. The DY3 is one that can.
The Yuneec supplier chargers are different between the H520/H Plus versus the H480 (H and H Pro).
Note: The H and H Pro are the same airframe. The options make the difference.
Also, the H480 batteries will work in the airframe of the H520 and H Plus. I believe I have read that the LiPo HV will work in the H480, but do not recall exactly, and I not have personally tried. Therefore I am staying away from stating that as fact.
Hope this helps.
[Edit: @Phaedrus and I were composing our replies at the same time!]
