Typhoon H Pro and Plus NFZ
Yes
You can get a release but you need a 107 certification.
Some are saying at certain airports even with a 107 you can't fly?
I'm wondering if I went over to Orlando International Class B if my bird will fire up?
Might be interesting to see how strict their NFZ is. MCO is on the Yuneec NFZ list. Might be interesting to see how close to the airport you have to be for it to kick in. People report it is easy to get a release code from Yuneec. However, you have to connect your aircraft via the micro-SD to a Windows only computer in order to retrieve a code number off it (not the serial number). I can't get the USB drivers to work :mad:. No response (Surprise!!) from Yuneec Tech "Support" either.
Bdog
