ThanksRan a few more data points this morning and plotted Power (W) and Current (A) vs. Thrust (g). Let me know what other data would be helpful and I'll try to accomodate?
Glad you did it in g, most of the world has no idea what an oz is lolRan a few more data points this morning and plotted Power (W) and Current (A) vs. Thrust (g). Let me know what other data would be helpful and I'll try to accomodate?
Keep us posted. Im eager to learn how it goes .Just found this thread. Great work KC3FPV.
I'm considering swapping out the motors on my first H and fitting it with a set of Cobra motors. Looking at the specs you have got, I think the 2213/36 700kv model is going to fit in pretty nice. Looking at their data sheet, the specs seem to align pretty well with your findings on the standard H motors, which should mean that I will be replacing the unit with motors which should put no additional load on the power system. If anything, I think they will run a little more efficient. I also plan to use the Master Airscrew 9 X 4.5 multi rotor props with this set up. It will be a little while until I can get this all done, but finding this thread has certainly helped me in trying to work out a replacement motor of similar specs.
Making a universal prop adapter and have some 9x4.3 and 9x4.7 props on order. Also looking at Graupners 9" tri-props. Will post data when I get the comparisons done.
Did you ever get any new data, I made some prop adapters too.
Ralphy - did you end up making a 'universal' type prop adapter? The only ones I have seen, so far, will only take a DJI style prop. I have some new Master Airscrew MR props that I would love to try on my H, but they are made for a straight M6 motor shaft.
