Typhoone H Plus
Norway
My Typhoon H Plus doesn't go forward when the Obstacle Avoidance Switch is turned on. When I turn it off its fly beautifully. I have tried it high and low with the same results. Has anybody had the same problem?
@sibelius had the same trouble with his back in 2019. He might be able to give you some details about it.
I would suggest going into settings and disabling the RealSense module, then try the obstacle avoidance using just the forward facing sonar sensors. This can help isolate if the base sonar is the problem or the RealSense module.
The good news is that you are in Europe and still have access to Yuneec Customer Support.
paulrs
