Updated Firmware: BUILD757-20180906
How old is this version?
Question for those who have upgraded to 757, do you still receive the "Takeoff Location Recorded" notification when you acquire satellite signal? I'm not receiving that on mine after acquiring 16 sats on the drone and 12 on the controller. I'm afraid to take off with out seeing that.
you have to open the historical window
I did not see your screen,
As long as "Current takeoff point recorded" is displayed after starting the engines, it's good
here a start engines without propellers just after having 11 satellites
Oliver, my screenshot is in the post. It is not displaying "Current takeoff location recorded". That's the reason for my post in here
yes yes I saw it well, my English is bad.
Did you do a test when starting the engines (without propellers)?
Yes I did. I get the error for the props not being on but still no "current takeoff location recorded"
The screenshot is a test with the props on. I thought I should try both ways just incase. When I get home I'm going to factory reset it and try again. I should have just sold this when I got it replaced by Yuneec.
My H+ is now on is way to RMA in Germany.
Yuneec says they need my baby for 10 days, and lets see witch firmware version the put on it...
Bummer :-(
Getting mine back from Germany tomorrow but on the bright side, its only been gone 6 days including postage :-)
Reactions: ECKEROTH
After factory resetting and putting 757 back on, my notification for "Takeoff Location Point Recorded" has started showing back up again.
zaim
