I will try your suggestion.Are you making sure to stop recording before powering off? This scenario will result in a corrupted file, but it can many times be recovered by putting the sd card back in the camera and cycling the H power on and off.
That worked! Thank you. Apparently I did not turn off the camera before I landed
That should work. Wish I’d known that when I started. Some of my best work got lost to file management errors. We could have a class on labeling and data storage as I’ve got terabytes of footage and naming to find later is tricky. Plus making back ups of your work as I’ve had drives go and loose stuff also.
