What antenna is best to use for the video, round or rectangular?What antenna is best to use for the video, round or rectangular? What is difference between the ST16 with two antennas and ST16 with three antennas?
The round does not provide as much range, but it does not need to be precisely aimed at the drone. The flat provides greater range, but must be accurately aimed at the drone. Video loss will occur suddenly if you inadvertently point the flat antenna away from the drone. It's a trade off. Which is "best" is different according to the specific use at the time.
Not much. The older ST16 also has three antennas. The third is inside the case where you can't see it.
There is a reason for that. Loss of video lets you know you are also nearing the end of control range. Some have increased video range without sufficient increase in control range. The result is you have a great view from a drone you can no longer control. You can only hope the system's automatic response will work for the conditions of the event. If you turn off or loose GPS, pretty much all you can do is throw it a kiss good bye.Seems like the video range is not consistent with remote control signal range?
"Throw it a kiss goodbye"??? does the Typhoon H not know when it has reached end of transmission range and turn back like Mavic Pro? You would think the TH would know or at least warn when at or near the end of transmission range?There is a reason for that. Loss of video lets you know you are also nearing the end of control range. Some have increased video range without sufficient increase in control range. The result is you have a great view from a drone you can no longer control. You can only hope the system's automatic response will work for the conditions of the event. If you turn off or loose GPS, pretty much all you can do is throw it a kiss good bye.
I'm no expert in aftermarket antennas or boosters. There are some related discussions that you may be able to find using the search feature.
One of the best. I take it your US? So you have more power than EU Firmware, which can be a pain, this pretty much eliminated my issues.
Raptor SR
www.4hawks.com
Yes the Typhoon H will go into an auto loiter mode on control signal loss and hover in place. After certain conditions are met it will perform an auto RTH."Throw it a kiss goodbye"??? does the Typhoon H not know when it has reached end of transmission range and turn back like Mavic Pro? You would think the TH would know or at least warn when at or near the end of transmission range?
Note the phrase "You can only hope the system's automatic response will work" in my response. The backup systems are not infallible on any system. I prefer not to rely on them. I'm not everyone."Throw it a kiss goodbye"??? does the Typhoon H not know when it has reached end of transmission range and turn back like Mavic Pro? You would think the TH would know or at least warn when at or near the end of transmission range?
At least you guys don't lose video as soon as you lift landing gear up just above you.Note the phrase "You can only hope the system's automatic response will work" in my response. The backup systems are not infallible on any system. I prefer not to rely on them. I'm not everyone.
The loss if video is something of a warning for those that choose to heed it.
I use it because the EU firmware can and often loses video feed only a few meters away, and can take 90 seconds or more to re-establish.even turning the copter, it's not used for extra distance, just to eliminate those problems.When you say "one of the best" are you speaking about the antennas I asked about? If so what benefits did you notice? I have the US firmware
Thanks for the update, will continue to fly and learn more about this drone. Not sure if I like it better than my Maic Pro just yet.I use it because the EU firmware can and often loses video feed only a few meters away, and can take 90 seconds or more to re-establish.even turning the copter, it's not used for extra distance, just to eliminate those problems.
thanks for the update, what can I purchase to increase video range? Seems like the video range is not consistent with remote control signal range? What about the antennas show in attachment, will they provide better video and control transmission?
The 4hawks has improved it for me, but still get the odd video loss, it seems inherent of the weaker power output, and possibly the DFS digital switching, to stop interference to external services like radar it's claimed.I know that issue, thought it's only me. Immediately after landing gear switch is on - video is cut off.
It happened to me many times. I don't know the solution.
Brushed motors are well known for their RF interference. You need to add a RFI suppression film capacitor on each landing gear motor. I use 100nF film capacitor (marked with 104), which we find in nearly all electronic components.I know that issue, thought it's only me. Immediately after landing gear switch is on - video is cut off.
