WTFDproject
Moderator
Staff member
Premium Pilot
North Carolina Piedmont, USA
The attached index (Table of Contents) is a compilation of MEMBER GENERATED INFORMATION. The accuracy of all information is limited to the observations and interpretations of the contributing member(s). Errors may be present. It is the responsibility of the user to evaluate the information prior to use.
The intent is to provide a resource for issues related to our hobby. If you have any guidelines, drawings or useful information, please post in this thread. You will be given credit for the information. Material covered by copyright will not generally be usable. However, links to the original information generally will be. Links to YouTube videos you found informative may be usable. Use of all links to external media must conform to Forum Guidelines.
"Table of Contents.docx"
Date of latest revision: 06/28/2026
Overload protection at Q500 battery.
Added as new Enclosure 33.
The document needs a new structure for firmware links. A new attachment, dedicated only for links, will be added sometime this evening.
Thanks. This is good.
Better put the coffee on, long night ahead.
Reactions: WTFDproject
Uploaded new Revision 16.
Added Attachment 39 (Pitch, Roll and Yaw Discussion). This document was prepared to facilitate a rather complicated discussion of Gimbal Stabilization that never actually happened. Since the relationships between drone and camera movement can be confusing, it seemed at least worth keeping as an attachment to the document.
See "Way To Fix Drones project".
Reactions: AH-1G
This document is a compilation of MEMBER GENERATED INFORMATION. The accuracy of all information is limited to the observations and interpretations of the contributing member(s). Errors may be present. It is the responsibility of the user to evaluate the information prior to use.
The intent is to provide a resource for issues related to our hobby. If you have any guidelines, drawings or useful information, please post in this thread. You will be given credit for the information. Material covered by copyright will not generally be useable. However, links to the original information generally will be. Links to YouTube videos you found informative may be useable. Use of all links to external media must conform to Forum Guidelines.
Everything looks to be intact
That is truly an impressive repair guide!
No modifications. These are three variations I have seen on at least two cameras each. The "at least two" is my homemade "criteria" for deciding if it is a factory variation or a user modification.
On page 210 the links are broken. When I click on the links a " was added at the end of the address. Please remove the "..." from link addresses.
Thanks.
If you want, you can add the link to custom firmware Thunderbird:
The Thunderbird discussion is here:
Thanks.
@h-elsner,
Try the links now. They work on my machine, but perhaps not on all. I made the link to the Thunderbird Thread point to Post #11. That seems to be where the real discussion begins. But if you think it should go somewhere else, please let me know.
Date of latest revision: 01/02/2020
A lot of time you spent on this. Great work.
skonsk
