WTFDproject
Moderator
Staff member
Premium Pilot
North Carolina Piedmont, USA
This document is a compilation of MEMBER GENERATED INFORMATION. The accuracy of all information is limited to the observations and interpretations of the contributing member(s). Errors may be present. It is the responsibility of the user to evaluate the information prior to use.
The intent is to provide a resource for issues related to our hobby. If you have any guidelines, drawings or useful information, please post in this thread. You will be given credit for the information. Material covered by copyright will not generally be useable. However, links to the original information generally will be. Links to YouTube videos you found informative may be useable. Use of all links to external media must conform to Forum Guidelines.
NOTE: The WTFDproject.PDF is a collection of attachments arranged by attachment number. It contains its own menu at the front of the Document. Once you are in the PDF document, scroll down the MENU to find the Attachment you need. Click on either the Attachment Title or Attachment Number, and it will take you to the actual attachment within the same document.
NOTE: The "Table of Contents" version attached is a compilation of direct links to individual articles and may be more convenient for many. The articles in this format are grouped by subject/title rather than by Attachment number. The articles in this format are also significantly more up to date.
Date of latest "WTFDproject.PDF" revision: 03/11/2022
Date of latest "Table of Contents" revision: 04/07/2024
  • WTFDproject Rev89.pdf
  • Table of Contents.pdf
Added as new Enclosure 33.
The document needs a new structure for firmware links. A new attachment, dedicated only for links, will be added sometime this evening.
Thanks. This is good.
Better put the coffee on, long night ahead.
Reactions: WTFDproject
Uploaded new Revision 16.
Added Attachment 39 (Pitch, Roll and Yaw Discussion). This document was prepared to facilitate a rather complicated discussion of Gimbal Stabilization that never actually happened. Since the relationships between drone and camera movement can be confusing, it seemed at least worth keeping as an attachment to the document.
See "Way To Fix Drones project".
Reactions: AH-1G
Everything looks to be intact
That is truly an impressive repair guide!
No modifications. These are three variations I have seen on at least two cameras each. The "at least two" is my homemade "criteria" for deciding if it is a factory variation or a user modification.
On page 210 the links are broken. When I click on the links a " was added at the end of the address. Please remove the "..." from link addresses.
Thanks.
If you want, you can add the link to custom firmware Thunderbird:
The Thunderbird discussion is here:
Thanks.
@h-elsner,
Try the links now. They work on my machine, but perhaps not on all. I made the link to the Thunderbird Thread point to Post #11. That seems to be where the real discussion begins. But if you think it should go somewhere else, please let me know.
Date of latest revision: 01/02/2020
A lot of time you spent on this. Great work.
Sierrarhodesss
