To add to what I posted earlier;
There is no need to blend multiple exposures or try HDR unless the camera cannot capture the full dynamic range.
In a DSLR there is a histogram which shows you if you have lost any detail by clipping the highlights or shadows. This means that there is zero information in the image and it will show as either totally white or totally Black. In the CGO3+ we do not have the luxury of a histogram so we have to decide if we are clipping by eye. If we are or think we are then this is the time to take several images. If you have software like photoshop then the H is steady enough and the software will align the images for you and then you can blend them manually if there is a need or desire.
In my image above I took several exposures at different settings as it is straight into the sun and there are also some quite dark shadows, but in fact I produced the image from just one exposure, the CGO3+ actually did a better job than I expected. True it is quite dark in the bottom corners and i could have brought that out from another image but I quite like it how it is. (The little white dots are sheep by the way
Some other things to consider if you are not a photographer:
Even though we are shooting aerial we must not forget that we still need a good composition, it is easy to get carried away because it looks so good as we fly. I am sure we have all looked at a fantastic viewpoint on holiday and taken a snap of it, only to be dissapointed when we get it home.
With a camera we need to compose to keep the eye interested. There are many ways to do this but consider not going too high, we can get a unique viewpoint at just 20 feet sometimes. Perhaps use a tree as foreground. Think of using leading lines. One reason the image above works is the hill which is nicely lit leads the eye to the sun and then keeps the eye in the image by exploring the rest of the frame. Try doing this with a winding river, a line of trees or rocks.
Other things that can work are diagonals, repeating patterns, odd numbers like a single tree or three objects, isolation, juxtaposition and many more techniques.
Apologies for rambling on, below is an image that works on diagonal patterns and a right to left leading line that leads to a small hill, without that small hill the eye would probably wander out of the image, I will leave it to you to decide whether it works, but you get the idea
