I phoned it's in stock, but can you believe sales people, for the price though I think I might add the extra money and progress to a plus.yes, is it on store just now or being there for a long time?
How much would you pay for a C23 camera on H?I phoned it's in stock, but can you believe sales people, for the price though I think I might add the extra money and progress to a plus.
Well at £900 nearly and a plus at £1349 then I would say not worth it.How much would you pay for a C23 camera on H?
10%, 20% or 30% discount then you would put the order?Well at £900 nearly and a plus at £1349 then I would say not worth it.
£300 I might, but the 480 is an old model now, and the C23 not really designed for the H, bigger and better the plus model, so I'll save up for that.10%, 20% or 30% discount then you would put the order?
If anyone actually believes this advertised C23 camera is available for the H, call the vendor and ask where on the Yuneec site you download the FW update, that adds the C23 to the available camera model list. While you're at it, ask them the specific FW version number, which adds that capability... post their response here.I phoned it's in stock, but can you believe sales people, for the price though I think I might add the extra money and progress to a plus.
They'll sell it to you, and say " It will be released soon". Sales people have the gift of the gab!If anyone actually believes this advertised C23 camera is available for the H, call the vendor and ask where on the Yuneec site you download the FW update, that adds the C23 to the available camera model list. While you're at it, ask them the specific FW version number, which adds that capability... post their response here.
If read I did and they said yes they have bothThe ad specifies 2 versions available, one for H and one for H+
It would be too easy to call them and confirm.
But why would you at that price???
It does fit and it will power up. You just have to use one ST16 for the H and a ST16s for the C23. Kind of like Team mode only different.I can’t believe some people still think a C-23 is, or ever will be available for the H-480.
This came up in another post and was cause for a little confusion, which I have since cleared up. So I thought I would take the opportunity to clear up any miss conceptions about what works and what doesn't work.It does fit and it will power up. You just have to use one ST16 for the H and a ST16s for the C23. Kind of like Team mode only different.
Exactly. I can understand using it with the SteadyGrip but on with the H.The only solution to using the C-23. If you want to use one, buy an H Plus.
If some users are really willing to get a C23 for H, I think it's not a technical issue.The only solution to using the C-23. If you want to use one, buy an H Plus.
I think the confusion was brought about by Yuneec themselves who promoted both versions of the C23 for plus and H, it is still on their website and shops in UK still advertise both versions, some say in stock! Clearly they need to sort out the confusion they started, not everyone is on a forum and fully aware of it's incompatibilityThis came up in another post and was cause for a little confusion, which I have since cleared up. So I thought I would take the opportunity to clear up any miss conceptions about what works and what doesn't work.
This "Kind of like Team Mode" experiment has been conducted by the mad scientist in Dr FrankenPhoon's laboratory, and the results support what Steve has maintained about gimbal control being a function of the 2.4gHz control link.
The end result of binding the two controllers to their respective devices resulted in neither controller being able to control the gimbal. This is also supported by the fact that in the ST16 we can control all the rates of every 2.4gHz channel, the Tilt and Pan are Ch7 & Ch8.
The final proof:
The gimbal only needs power to activate the camera, the 5.8gHz link, and the basic gimbal centering and leveling functions, so even when the CGO3+/C23 is mounted on a SteadyGrip, the ST16/ST16S will receive the video feed and can control all camera functions and settings via the 5.8gHz link, but there is no gimbal control thru the ST16/ST16S 2.4gHz signal because nothing is bound to it, this is only accomplished with the tilt knob on the SteadyGrip, a signal coming thru the gimbal mounting plate, not the 5.8gHz antenna.
A note on the C23 and the SteadyGrip/Actioncam. The C23 will mount and power up in a SteadyGrip, however the location of the 5.8gHz antenna interferes with the battery compartment so the gimbal is not free to articulate without making making modifications to something. I will likely hack my grip to create the necessary clearance, unless I discover the C23 antenna is easily removable.
