Yuneec H st16 channel settings
Hi can some one help me with the channel settings on st16 the default one thank you
Are you trying to make new adjustments, or are you trying to remove adjustments you have already made?
If you are wanting to intentionally make new adjustments:
What are you wanting to change?
Are you trying to correct a problem with the controller?
If you want to remove adjustments you have already made:
You can return to the standard settings by deleting the Model (or models) you were on while making adjustments, and create a new Model.
A factory reset will also clear all adjustments made in channel settings.
Reactions: DoomMeister
This statement is not always true. Tested by me.
More than, model export and import work almost correctly, not 100% trusted solution without a full check.
CKHD
