Yuneec q500 4k firmware, st10+ firmware and cgo3 firmware
A good practice is to look at the sticky threads and using the forum search (magnifying glass icon near the top.
Thread '???Yuneec Downloads???'
Reactions: Murray Martz
Thank you very much for this.
Now after doing all the firmware updates my st10+ dont want to connect to my cgo3. If I use mobile it connects but not the st10+. What can I do to fix this?
What step is not working when you try to bind the CGO3 in the Bind menu of the ST10?
If you can bind to a mobile, the WiFi hotspot of the cam is working.
If you hit 'Refresh', the SSID is showing up or not in the Bind menu?
If Keep the st10+ close to the cgo3 it binds but when I move away the live stream stops working. So I have no live video feed when im flying.
All CGO3 and 3+ have a very terrible issue with the antennas. The ground side of the solder joint brokes and antenna stays connected only to the center wire of the coaxial cable. I have found this problem in all the cameras, which come to me for spares or repair.
A better one...
Hi. Do you have an idea why this happens? Vibrations? Pitch movement?
I know that the antenna is not blocked into his housing.
Can the ground be soldered again?
I have no idea why this happens. I just shared a fact, observed by me. Everything can be soldered and resoldered. This one, on the picture, is resoldered.
trepox
