Yuneec_Usa whats up with the HDMI issue?
Georgia
Haven't heard a peep out of Yuneec in regard to both the ST16 HDMI external device compatability issue and the ST16 screen going blank when used in conjunction with and external HD device that does work. Once the two devices are paired,if you tap the ST16 screen to turn the telemetry overlay off the ST16 goes blank.
When do we expect a fix for these issues?
Reactions: Bobjazz
Is this something in an Android app on the ST16 controller? If so where is it? Thanks.
From the video description:
You'd need to download shortcut creator from an apk mirroring site.
Install , and create an activity shortcut for HDMI from the hidden list.
"More Shortcuts" apk: More Shortcuts
just put it in your sd card and install.
Reactions: horizontal
Thanks for the link. What I,m referring too is the handshake between the ST16 controllers HDMI out to an external HD device. That has something to do with the HDCP protocol.Would the apk mirror site have such a compliance protocol that can be nested on an SD card,then loaded onto the ST16?
wiebeedigital
