Need help or advice
Zin
Hi I am typhoon H user from Singapore. I just tried bloated battery to battery encasement and cannot take out from there. Anyone can help or advice for removal of batt?
So you don't have a Mantis? Might try letting it cool down it might slide out after a while. You should be cautious because it could get damaged and set on fire, you may have to dismantle the H to get it out.
Reactions: KEITH KUHN
Here's the view with the bottom cover off from the thread.
Reactions: DoomMeister
Put it in the refrigerator overnight. Or even the freezer. I've found the swelling is significantly reduced below 0° C.
marcojanson67
