Can you give us and idea of the condition of the battery and internal resistance values of the cells. I can send you a free charger adapter if you willing to give us info we can use to analyze if something is wrong with the battery . Poor soldering or a failed soldered connection can cause an intermittent issue like that. Once it smacked the ground the joint might temp reconnect and under load fail again.
