A little opening drone video using CCC while controlling the camera. Not bad for my first attempt: https://vimeo.com/313546816
Nice!, Was this the H or the +?
What camera did you use for the ground?
You did come very close to that tree:):oops:
480 Pro walk through was shot on a Sony A7R3 w/ 18mm Zeiss Batis 2.8 lens on a Movi Freefly M10 gimbal and Atomos Ninja Inferno external monitor and recorder.
Reactions: AH-1G
Nice job. I too was concerned about using CCC that close to a tree. While the GPS positioning is very good, the altitude control is not. Since CCC rounds out the waypoints when flying the route it may be closer to obstacles than the original flight.
In any case, it worked out well for you.
That’s why I wish Real Sense would be able to be activated when flying CCC.
Clean work! Thanks for sharing
sakshijah
