What are you calling "round"? the small whip antenna or the mushroom type?my drone cam with a round and a square antenna which one should I use
Some H pros came with 2 5.8 antennae,either or 2 be used in center application. One is called mushroom,or round, while the other is a square or Patch,they say is more directional but more range. KeithWhat are you calling "round"? the small whip antenna or the mushroom type?
here's a manual if you already don't have one for the Hmy drone cam with a round and a square antenna which one should I use
Don't need to lose sight with EU firmware, just raise the legs!The round antenna is omnidirectional, the square one is directional. Omni is wide beam, directional is narrow. The narrow beam has to be aimed directly at the aircraft all the time. The wide beam does not.
If you are not proficient with flying multirotors, and don’t always have the 5.8 antenna aimed at the aircraft, use the round one.
With either antenna, if you lose sight of the aircraft you can run into problems. Those problems will be self induced, but still problems. Avoid having problems by keeping it in sight.
