camera only tilts up when using the controler its does not go down works with pilot mode
the breeze is brand new all fuctions work but no camera tilt down it does work with in pilot mode with the cam do I have a defective controller when you are fling the up arrow spins the drone around thanks
corey
I read your note as saying:
1.) Everything works correctly when flying with just the phone
2.) When using controller, you have a problem with "down tilt" does nothing, and the "up tilt" is causing the drone to spin.
Is this correct?
jonnyelectric
