Eric, it seems that the 'delete mode' isn't working anymore in version 1.7. I'm using Firefox and Safari on a Mac.
Anyone else seeing this problem?
I noticed this as well.
I'm using the browser built into the ST16.
FIXED !Eric, it seems that the 'delete mode' isn't working anymore in version 1.7. I'm using Firefox and Safari on a Mac.
Use the File Manager appI've used my ST16 controller to edit a CCC flight that I've done before. I everything seems okay except when I go to save it. It saves in the 'downloads' file of the 'pad' of the ST16. How do I go about moving it from the 'downloads' folder of the 'pad' to the location 'internal storage\flightmode\mission_data' ?
Thanks for the quick response.
I've tried to use it, but I don't see anything in it that lets me move the file to the proper location.
Mistral??OK, I prepared three CCC from very simple to complicated.... Ready for testing tomorrow morning (the Mistral is blowing VERY hard)
I need all the night for praying![]()
Yes I'm preparing my board and my sails for a afternoon in l'Almanarre !Mistral??
Where are you Eric? Provence / France??
After a long press of the file:File Manager
-downloads
-long press your file to select
Do you get the option to move, copy, etc?
Thanks again for your great work. If I'm creating waypoints and the second waypoint is 150 ft. higher in elevation and between the waypoints there is a gradual increase in height do I adjust both waypoints? If waypoint 3 decreases in elevation do I address that by adjusting waypoint 2 or 3?
I'm sorry you regarded my question as vague...it's how to change elevation from waypoint 1 to waypoint 2. I wanted a gradual climb until trre line then more pronounced. The first waypoint of which is 30 feet in height the second is 150 ft in height. I've answered my own question I need more waypoints which gradually increase elevation along the way. I'm starting in a valley climbing to top of valley then descending back into the valley from another direction. There will probably be 8 or 9 waypoints to smoothly compensate for elevation differences.150 ft higher in elevation in relation to what ?
How many way points ?
What are you trying to do ?
(Your description of what you're trying to do is rather vague.)
Only get the options copy, cut, delete, share, add favorite.
Do a simple test out in a open field. Point A at one end and Point B at the other end. Do the route and watch the climb rate or even take the telemetry and put it into Exmaps.com to watch it 3D. That way you will know how fast the elevation of the H is going to change to each waypoint.
Use the 'Cut' option, then navigate to the folder path (\storage\flightmode\mission_data), you will get the option to paste in the folder.
My bad I was confusing you APP with Tuna's....thus question would make no sense to you...it may not even make sense to Tuna.Sorry but my english is very poor, and it's very difficult for me to understand your question.
