CG03 camera
Ok. Now that I have the camera working and the right propellers, I don’t get telemetry data anymore. Any idea?
Ok. I did that. Now when I power up the drone it has an intermittent beeping. I also don’t see the aircraft in the binding process.
I just replaced the SR24. But I had that working. I also don’t see a problem with the connection. That is one **** of a wire run. lol. Could it be that again??
Can you describe the pattern and timing of the intermittent beeping?
Otherwise, you need to run the Binding verification below to identify the failure point. Select CGo3 at the camera steps.
Typhoon H Binding Verification
Probably not. The TH will power up without any beeps, even with the SR24 missing. The only "easy" thing I know of that creates beeps is if the GPS module is unplugged. The whole GPS module unplugged will give you an intermittent "High-Low, then two beeps" pattern and repeats every few seconds. Not sure what it would do with individual components unplugged or damaged on the Module.
Too much speculation right now. Best to see how far into the verification you get before something does not match the anticipated.
Ok. I double checked the gps connection. It’s good to go.
When I turn on the drone it starts beeping. I do have camera connected.
There are 3 beeps/3 blinks then solid, back to beeping.
Is going through the typhoon binding process a possible cure?
"When I turn on the drone it starts beeping. I do have camera connected."
First, remove the camera and try again.
If it still will not start, tell us what is blinking 3 times. (All LEDs under the motors, some LEDs under the motors, the rear LED, or some combination.) What color is the blinking?
No, but it is a possible diagnostic. Start working through the verification. When you come to a step that does not match what the step says to expect, then come back to the forum and tell us the step number and what you saw that was different.
Have you connected to the GUI to see what it shows?
Alright I encountered an error at step 34. When I turn on the Drone the motor lights all flash 3 times. There is also a beep 3 times.
The rear light flashes blue-orange.
How do I do that?
Download the setup (exe) file from the following link. Run the file to install the GUI.
The first page of the GUI briefly tells how to start things up, but the video in the attached link does a much more complete job.
I can't seem to find the support page at Yuneec.com
I tried Drop box, but it said I needed permission and sent a request
.. it said I needed permission and sent a request
Not sure what happened with Drop Box. I'll have to figure that out, but in the meantime, here is the actual file:
See if this link works Version 1.2.13
This is from Yuneec Skins via web browser instead of the Dropbox app.
alexphm
