- Joined
- Aug 30, 2024
- Messages
- 110
- Reaction score
- 21
- Age
- 58
Ok. Now that I have the camera working and the right propellers, I don’t get telemetry data anymore. Any idea?
Sounds like you selected a different model at some point. Try rebinding the drone side of the binding sequence. You may have to create a new model and start all over again.Ok. Now that I have the camera working and the right propellers, I don’t get telemetry data anymore. Any idea?
Can you describe the pattern and timing of the intermittent beeping?Ok. I did that. Now when I power up the drone it has an intermittent beeping. I also don’t see the aircraft in the binding process.
Probably not. The TH will power up without any beeps, even with the SR24 missing. The only "easy" thing I know of that creates beeps is if the GPS module is unplugged. The whole GPS module unplugged will give you an intermittent "High-Low, then two beeps" pattern and repeats every few seconds. Not sure what it would do with individual components unplugged or damaged on the Module.I just replaced the SR24. But I had that working. I also don’t see a problem with the connection. That is one **** of a wire run. lol. Could it be that again??
"When I turn on the drone it starts beeping. I do have camera connected."Ok. I double checked the gps connection. It’s good to go.
There are 3 beeps/3 blinks then solid, back to beeping.
Is going through the typhoon binding process a possible cure?
Download the setup (exe) file from the following link. Run the file to install the GUI.How do I do that?
Not sure what happened with Drop Box. I'll have to figure that out, but in the meantime, here is the actual file:I can't seem to find the support page at Yuneec.com
.. it said I needed permission and sent a request
