Change Flight Log MAPS to SATELLITE view?
I believe that you have to click on the 3 dots in the upper right side of the screen when you have the app opened up and unselect google maps.
that should then open up the flight log okay when you select the flight log that you want to view.
(at least if that's what I'm thinking about. I can't check since I'm here at work for another 1.5 hours)
Yes this works . Thank you very much
Or use Flight Center, which has Satellite view as well as vector maps ;)
Captain Drone, if you had been using the egg carton and aluminum earlier you would have seen the maps before.:D:D:cool: Tuna's creation is marvelous.
I have meaning to ask if when using the egg carton system the information gained from Tuna's app can be scrambled for confidentiality reasons? ;)
Actually, when using the egg carton and my App together, you can get Satellite TV on the ST-16, and all of your bank details are beamed directly to the FBI. It's not a bug, it's a feature.
Reactions: Lumberjack0
I was also able to microwave my popcorn while flying thanks to egg carton and aluminum hack!
Reactions: Tuna
C_Wayne
