I do not have a breeze, most likely a pitch number and blade length.
6-3 would equal a 6" diameter with a 3" pitch.
If you can post a pic of the blade we could better tell.
Oh this makes sense. Thanks!I am willing to bet those are Tool marks.
During the plastic injection, the tool or die may have the ability to make many blades at once. So each blade spot in the die is numbered.
Should they have an issue, they no exactly where in the die the blade was made.
I'm using the one they gave me with the drone.Be careful when replacing propellers. The original props weigh ~0.6g while some non-branded props weigh ~0.8g. The Breeze will drift while hovering with its motors trying to compensate the fast spinning unbalanced weights.
You'd better off buying genuine Yuneec props that come in Yuneec labeled bag for spares.
Yeah, same, thanks.I also wondered about that difference in fits when replacing props. Some props felt loose, some props felt tighter on the motors, but I'd loose the locking screw a little bit if it felt too tight.
I found no issue in flying regardless.
Physically, when taking off, motors starting to spin, the loose props or the tighter props would swing out with centrifugal force. However, I'd always swing out the props by hand to ready the flight. I have tried taking off with the props folded, the drone would take off nicely, too.
The tighter props worked better when putting the drone in the case or taking it out of the case. The tighter props stayed folded so they wouldn't hit the case's top when closing.
