Drone Test
Good day friends! Regarding the constant sound that the drone presented. I did test turning on the drone without turning on the ST16 and it made no noise. I turned it off and then turned it on after the ST16 and it made no noise either. He behaved as if nothing had happened. It should be noted that this time I did everything away from home. The problem was inside the house. I haven't done a test flight yet.
If it does any rapid beeping
before you launch, do not
take off. It's possible
you could get a flyaway.
And we don't need those.
Keith Kuhn
Reactions: IMAWARI
It is likely the right stick that is causing the problem. It must return to exactly zero when the stick is centered. Go to Hardware Monitor and check the sticks to make sure they go full scale and react smoothly. If they are sluggish or erratic, the stick may need cleaned.
I must learn more about it because I don't know where to see that on the hardware monitor. Please! Could you tell me how?
Steve I thought you retired from the forums ? I'm glad your still active, just thought I'd ask is all. Thought you'd be golfin more, or dancing with the pooches :D
Write your reply...
mrtermite
