Fr need help after an accident.
Hello, today my controller's battery was in trouble, due to a problem my controller gave a battery warning and warnings that it would shut down in 15 seconds. While I was trying to connect my q500+ controller that ,I had left before, I saw the quadcopter floating and I knelt down and thought for a while, then when I ran to the bird I saw two arms and the metal camera parts on the ground. Now I'm home and I think I'm fed up with the hobby. Will the q500+'s case fit? I think so but I still feel like I've lost interest. I don't know what to do, the camera only gives an image, the gimball doesn't work. Maybe if the q500+'s case is made to 4k, myb it can fly again. I don't know, please help.. 🥺🙁
q500+ and q500 4K are basically the same drones, but have different cameras. Parts are interchangeable.
Older Q500 may have a ST10 instead of ST10+. I'm not sure if ST10 supports CGO3Pro but I think with latest FW - yes.
What kind of help do you need?
Reactions: 7cyclops and alkan
For example, the upper bodies look the same when viewed from above and the battery place. The screw locations and dimensions are also the same. Do you think I can change the upper and lower cases? With the 3D printer, I can make additional parts for the places that don't fit. But the worst thing is that the main gimball shaft of the cgo3 is bent. and it gives an error. I don't know if it's worth the effort?
The 4K shell parts are almost the same. I think there is one extra screw in the 4K that is not present in the original. The missing screw is not a significant item. All functional joints of the shells match perfectly.
The landing gear can be different. The original landing gear for each version will not work for the other version. The replacement landing gear works for both versions.
Reactions: alkan
In 4k, there is no solid place left except the landing gear :D. Anyway, it's my lucky day. Thanks for your help.
Reactions: WTFDproject
Mine came with an st 12 which apparently came with some of them. Not sure why.
Reactions: alkan
Mihal05
