- Joined
- Dec 26, 2017
- Messages
- 151
- Reaction score
- 168
- Location
- Stockton, California
- Website
- www.jcommstudios.com
PatR, you bring up a very good point. "Paralysis through analysis". I suffer from this myself. After reading some of the posts here and Facebook, I get a little queazy about putting my birds up in the air. I gotta stop thatI don’t know that’s user adjustable with an H but 8 sats would be my minimum number.
To be completely honest, I don’t care what UAV Forecast has to say about that or the KP index as the ST-16 displays what I need to know where I am flying, not some generalized info encompassing several continents.
There’s a term; paralysis through analysis, that will quickly hamstring people that get too wrapped up in data of questionable usefulness.
@FlushVision Thanks! it appears you understood the question. I use UAV Forecast as a somewhat informal guide to what the conditions are and generally keep the indicator at 15 as a basis. I read that 5 is acceptable in flatland areas which adds a bunch of Sats. First day, in a while, that it is not hotter than **** here in the California Central Valley and haven't flown the H in a while. I've been shooting with the EVO and the H480 needs some flight time. I noticed the Sats start falling off around 1:00 PM at a setting of 15. At 5 it indicates there are plenty all day. Going to shoot out in the Delta which is in "The Big Valley" and very flat for miles. Thanks for confirming my thoughts! JimDepends on where I'm planning to have a fly. Open countryside far enough away from any significant hills or trees or if my take-off point is on higher ground than that surrounding me I set it to 5. If on lower ground or with trees fairly close by then it's 10. In a valley or next to a high hill, or if it's an urban PfCO flight it's 15
So, it's where I am and what is around me that determines the settings I choose.
Do you feel in UK the lower setting is beneficial? Do we really have any areas possibly Scotland I suppose where using higher Sat's would help, just curious.Depends on where I'm planning to have a fly. Open countryside far enough away from any significant hills or trees or if my take-off point is on higher ground than that surrounding me I set it to 5. If on lower ground or with trees fairly close by then it's 10. In a valley or next to a high hill, or if it's an urban PfCO flight it's 15
If flying in an urban area (legal under PfCO Exemptions) a high setting is helpful to mitigate for surrounding structures since those buildings are going to shadow GPS particularly during take-off and landing phases. Same with hills. Living next to the Pennines I have my fair share of them things. A lower setting is only of any benefit when the take-off point is on higher ground...taking off from the top of those said hills.Do you feel in UK the lower setting is beneficial? Do we really have any areas possibly Scotland I suppose where using higher Sat's would help, just curious.
If flying in an urban area (legal under PfCO Exemptions) a high setting is helpful to mitigate for surrounding structures since those buildings are going to mask GPS particularly during take-off and landing phases. Same with hills. Living next to the Pennines I have my fair share of them things. A lower setting is only of any benefit when the take-off point is on higher ground...taking off from the top of those said hills.
At this point a take a nod to what @PatR says that curvature of the Earth not being an issue to LOS flights but I still see nearby structures and hills as a concern in regard to Mask. For example, I also fly an elderly P2V+ (thinking of retiring it though) which will only 'see' the American GPS constellation. However, it requires to 'see' at least 6 useful satellites for a GPS assisted flight. Many is the time I've taken off from a place where mask has been an issue and finished up doing the flight manually. When flying that P2V+, then, I've always found it helpful before setting out to consult resources for current satellites count with a higher mask setting than I would with my TH and choose my take off point with more care. Indeed, if the number of sats predicted 'seen' is on the low side I may choose to use my TH instead since it can see multiple constellations...to date I've never had an issue picking satellites up when using my TH except when taking off next to a building. I can't say that for my P2V+...I learned quickly how to fly manually with that thing.
I can see the benefits for some areas, I suppose for now I fly possibly restricting myself by not flying any urban or areas as such, just hilltops of the Cotswold's and open areas.If flying in an urban area (legal under PfCO Exemptions) a high setting is helpful to mitigate for surrounding structures since those buildings are going to mask GPS particularly during take-off and landing phases. Same with hills. Living next to the Pennines I have my fair share of them things. A lower setting is only of any benefit when the take-off point is on higher ground...taking off from the top of those said hills.
I did a commercial job at a church a few weeks ago (in an urban area incidentally). I had previously tried to do that job using my P2V+ but had to abandon the job because of the GPS 'shadow' from the church. I finished up doing the job using my TH but even that was iffy due to the shadow. It was a close up inspection of high gutters but the church tower was giving me grief.I can see the benefits for some areas, I suppose for now I fly possibly restricting myself by not flying any urban or areas as such, just hilltops of the Cotswold's and open areas.
@PatR I'm in Stockton. I have had a cabin in Murphys, on the creek, for years (well my ex-wife does now..lol) I'm up that way all the time. You should let me know where you are and perhaps we can meet up and shoot some footage some time. Lots of great places to shoot up there. All the best, JimWhere are you at in the Valley? I’m just above it in Calaveras County.
@PatR I'm very familiar with Valley Springs. Just about a 40 minute drive from my house which is off the Miracle Mile in Tuxedo Park in Stockton.We’re close. Valley Springs.
@PatR Sounds good to me. Yes it has been an extremely hot summer. Valley Springs is about the same as here temp wise. I'd be up for a trip and yep we can stay clear of the lakes and water shed. Lots of cool stuff to shoot other than lakes in the area if you look for it. Once the colors change, which should be soon, it is beautiful in the foothills. I would imagine Pardee is considered watershed. Always amazed me that they will allow motor boats but no swimming. I was up there fishing a couple of months ago and it was at 101% of capacity and the spillway was dumping like crazy.We should get together one of these days. Too darn hot to do any flying right now. Spring time up this way can be pretty, but we have to steer clear of the lakes. All the reservoirs and associated water shed are DHS no fly areas.
