U should try O.T.A. dismantling the camera before: but i think the updating go through the camera, so mit could not be possible...Dear Experts,
Does anyone knows how to update the H520 Flight Control without any camera on H520?
Thanks for your time!
Thank you, pretty impressive collection of releases, I will try some older ones. Thanks again!Check here maybe can help with older datapilot version: Yuneec - Google Drive.
Try manual binding with old datapilot.
I'm talking to them, if anything will come up I will update here in this thread.But to update it by hand it is necessary to put the SD card in the camera. Have you asked Yuneec to see if it can be upgraded via USB? By means of the computer the same can be done. Nothing is lost by asking.
To downgrade DataPilot SD card isn't necessary. You must only uninstall current DataPilot, copy older apk file to internal storage of ST16S via usb cable, and next run that file from file menager.But to update it by hand it is necessary to put the SD card in the camera. Have you asked Yuneec to see if it can be upgraded via USB? By means of the computer the same can be done. Nothing is lost by asking.
Yes the st16 can be downgraded fairly easy, but I would think that the 520 would also need to be downgraded as well. There could be some conflict, but maybe not...We're talking about the flight controller, but you've actually come up with the easiest solution. By downgrading the ST16S he can get it back on track
