- Joined
- Oct 30, 2016
- Messages
- 1,201
- Reaction score
- 439
- Age
- 47
according to the h520 manual page 46 you have to have the camera attached to get full flight status. without the camera gimbal you have no info on gps, battery ,speed, direction and other critical info. So far this pretty much means you need the camera to use this aircraft. the question is can the camera head (part the provides the video) be disabled with the rest of the gimbal full working and get full telemetry data to the st16s controller. what part of the gimbal enables the telemetry to be sent to the h520 st16s controller? Also hot swap cameras is out of the question as well page 4. On the maintenance guide what list of work is done for TBO or time between overhaul at the 500 hour in service mark? Is the annual flight maintenance same as the overhaul service. If not what work is done to the h520 for the overhaul service.
