Hi all. I'm new to forums in general, first timer.
I hope I'm communicating correctly. I just got a Typhoon H, first drone I've even seen up close. I spent some time practicing around my property and during the third flight my screen went blank. Can't seem to get it on again. Tried charging, taking the battery out and resetting that way. Nothing. I bought it used but it seems to be in very good shape, original box and all. Help?
@Debbie
Did you charge controller before flight?
Plug charger into the Controller, make sure controller is off.
you should here it power up for 2 to 3 seconds. after that tap on the screen and a battery logo will be displayed. It will show you battery status.
If battery was totally depleted, it will take 6 to 8 hours to charge back up.
Another person had the same issue. He was able to get it charged back to normal.
Welcome to YuneecPilots Debbie!
You can also use a USB power block from a phone or tablet to charge the ST-16 battery. As per AH-1G, let the controller charge to 100% as see what happens.
Reactions: AH-1G
jonnyelectric
