When you were connected to the GUI did you leave the props off and test the Motors individually and as a group?
If you did and they worked you need to refer to the manual and create a new model with a unique name (Bg TyH) and bind to it. Once you are able to bind to it and see telemetry on the left side of the ST16 and you get GPS Ready, install the props and arm the motors. DO NOT add throttle just let them run at idle for a few minutes then hold the arming button until the motors turn off.
Report your results.
Thanks again for your help, time, and responses. I had an amazing 3dr and after I added an aftermarket gimbal it flew a little funny. I checked the wires and rushed out to fly but leaving the gimbal knob turned as soon as I started to take off it went full speed 180 and crashed then caught fire. Sent it to the repair shop and they said they never got it.
Now I dont have the time to focus my attention with this one as the stay at home with the kid life some how leaves me with less time and I don’t want to spend money unless I know I can get it running. And if I rush it and crash cause I forgot to do something basic...
Already money spent on props, charging adapter, gimbal mount, are just the tip as I know there’s more I need.
Like the battery pack has a little swell and a few backups would be nice,
the landing gear has only one side holding(maybe you noticed it was held back in the video,
I wanna get the hand held gimbal mount (it looks like the cheapest way to test the camera),
prop guards (any recommendations)
and maybe the GPS move kit to allow cheaper aftermarket batteries fit (has anyone had a good experience with them).
—-ideas comments recommendations on the above —-
I thought I got a great as the typhoon and st16 for $300 is a steal. Now only if I could use it for more than a test of my patience...
So back to the problem at hand, I tested the motors with them props off and both individually and group. I didnt see any updates or anything that would let me know whither something was wrong or right.
Also I wanted to Update the firmware but couldn’t find the proper file. I’m going to try and turn it on with the props on and record it even though it’s dark outside. I hope I have more to offer as for clues to the issues of this drone , until them.
Thanks again
