Intel RealSense
Will the 520 be available with the RealSense module, and if so will you be able to choose custom distance settings through datapilot? Application for tower type inspection to sit a desired distance from turbine blade as you move along for example, at 4 meters off blade. Better yet an image lock through the e50 camera itself...or some combination.
playtime365
