RPR,
First things first... I am not writing to discount your findings, experiences, or opinions about your H+, build 777, or your particular mission environments.
What I want to ask is more related to your recorder setup, testing, etc al. I am coming from the perspective of having set up my own “copy” of Pat’s setup (TyPilot). I have yet to record an actual flight with successful playback, to the point of ordering a replacement recorder. (I have yet to test the new recorder.). The playback is worse than the example you posted, using my H480s and my H520. I know the actual ST16 live view was good.
What I am asking is this: have you already done so, or if not, do you have the means to record a test capture of your ST16s view, in a controlled environment whereby external factors are not an issue AND the ST16s display has no appreciable lag or stuttering? I am curious if your equipment will provide you with lag free video from an issues free ST16s “play” while your H+ is simply sitting on a table, motors off, and just panning the camera so some motion is detectable when replaying the recorded video.
Once “we” can confirm the recorder setup, including any memory stick used by said recorder can actually handle the job, we can then concentrate on the possible issues of actual flight.
Again, I only suggest this as a controlled troubleshooting process, given all the variables. As testers, we have to eliminate as many variables as we can, or confirm those variables are not part of the problem, before we can come to any sound conclusion (I.e. void of doubt and the inherent “what about this?”) as to what the real causes are for the issues we are observing.
Once the causes, conditions, et al are known as to the when, why, and where, only then can a real solution be sought.
Hope this makes sense and is not viewed as just another ramble.
Good point Jeff,
Let’s do a series of elimination, the only first build that I’ve only experienced is build 757 and now build 777
I don’t trust soft update and this goes with my other drones. I usually do a soft and a manual update. After each flight I check all of my equipments and load (camera) and all are logged. Preflight checkup, religiously, due to the type of flying that I do, and how I use my drone. My preflight includes all the calibrations, some are not frequently needed, but I calibrate them anyways. (IMU or accelerometer, and gimbal or gyro calibration)
The HDMI recorder, was tested prior to use, my memory stick is fast, and all of the recording equipment are working fine.
I haven’t flow the H+ in other locations beside within the construction sites, I fly daily in multiple locations and I yet to find a day that I can fly the H+ in other areas. Question, what good will that do? Does Yuneec expects its end users to fly in a somewhat perfect locations? There was a member on here who had a flyaway, and he flew in an isolated area. Knock on wood that I haven’t had a flyaway or a crash. Over the years of flying, I know when to land if there is a drop of doubt or signs of abnormality in my end or if my VO suspects that the sUAS is not flying as it should. Safety first.
*** I’ve shared this footnote on another thread. I have since replaced my 4hawks antenna back to the original antenna and it somewhat helped remedy some of the problems that I have been having with Build 777
The stock antenna is faster is gaining connectivity to the controller, but both antennas cannot seem to tackle the problem(s) that I am having. I’ve mentioned this before (because DJI used to have a connectivity issue that Litchi was able to solve) Yuneec need to invest time and money in making their FW close bullet proof, like what Litchi did for DJI or hire
@Tuna his UAV toolbox, from what I have been reading is very dependable.
Now, I have a request for you. Once you get your HDMI recorder setup to your controller, kindly fly your drone in busy areas. I at times wish that I have someone who can see the issue that I have been having in real time. There was a flyer in my area with an H480. He was the reason why I purchased my H+ because when I flew his sUAS it flew well in the trenches, but recently he sold his H and bought an Inspire.
I will run another series of elimination, Jeff. Give me time, because the weather here in California has been great and work is still in full swing. However, next week, I will do a downgrade to B757 FW and take it from there, but no promises, work is still a priority and I’m just blessed to be flying drones for a living.
Regards,
Akoni
