Just another battery charger question.
New York
I've used the search on this but didnt find the answer.
I have a Cellpro powerlab 8 charger, and it uses a Deans connector on it, I am wondering on the Venom charger adapter if its possible to cut the banana clip leads of it and solder on a deans so I then could balance and storage the Yuneec batteries? I know in the RC car world it can work but I honestly have no idea about it in this side of the hobby.
*EDIT* I thought I posted a link to the charger adapter but I did not.
Battery to Charger Adapter with Balance Leads For Yuneec Typhoon H Drone Premium | eBay
Charge adapters do not care what connectors are used at the charger side as long as they mate correctly with the charger's output connectors. Deans, banana, alligator clip, EC, are all the same for what the charge adapter needs to do. So yes, you can change the adapter connector. You could also make a Deans to banana adaptor and retain the plugs on the H adapter, or purchase a gang connector for that adaptation at a hobby shop. Several types are available for reasonable cost.
piscesflower
