Need to bump up your charger's settings. Mine will let me go to 4.25, but I keep it at 4.20.I have never ever of all my 13 Batteries get to 4.2
Even my new ULTRA X
Even my new ULTRA X
Yes. It appears your charger is not doing a complete charge. The battery cells should be reading 4.15 - 4.2 after a charge.So I need to purchase a new charger. My Venom Quad is set.![]()
Initially charged the new battery with the Yuneec charger, as I mentioned it read 3.89v per cell by voltmeter. My H controller showed it at 16.6v. ?????Yes. It appears your charger is not doing a complete charge. The battery cells should be reading 4.15 - 4.2 after a charge.
Oh well, one can only hope they will make another production run before discontinuing the 480 supply line. Forget about planned obsolescence, this is cleverly orchestrated obsolescence! Looks like were going to be forced to use the Plu$ and H520 batterie$, and in their geniu$, we will al$o have to buy different charger$ too! Totally brilliant!
Here's what I'm thinking; I keep my quad charger, and purchase a adjustable charger. Once my quads green light shows it's charged, I then reconnect the battery to the adjustable charger to finish the charging?
That or I'm going to spend lots of mula for and adjustable quad charger.![]()
Yes, ok I'll do that>AH-1G,
Are you using the venom 4 port Typhoon H charger?
If so, and it is not fully charging, submit a service request with Venom.com. You might be surprised at the response. A good response, that is.
Jeff
